Nicholson Hi Capacity Thermostatic Trap
Dave in QCA
Member Posts: 1,806
Here is a Nicholson high Capacity Trap. Pipe size is 3/4". Not sure what it is rated. Never used.
Best Offer plus actual shipping.
Dave in Quad Cities, America
http://grandviewdavenport.com
Can't seem to find specs on that
are there any more numbers on it? Do you know the seat orifice diameter?All Steamed Up, Inc.
Consulting0 -
I Will Open it and Check
Frank, I will see if I can get this opened up and measure the orifice. I also just corrected the original post. The pipe size is NOT 2/3", it is 3/4"! Ha!Dave in Quad Cities, America
http://grandviewdavenport.com0 -
the dimension is....
Sorry for taking so long on this. I tried to measure it and then forgot to get back to you.
I took the top off of the trap and then used drill bits to try to determine the size of the opening. 1/4" bit was loose and sloppy in the hole. 3/8" would not fit. I seem to be missing my 5/16" bit, but I'm guessing that is probably the size. I also opened up a Dunham 1E and the orifice in that looked about the same size. So, while it is a pretty nice size, it is not as big as I thought it would be.Dave in Quad Cities, America
OK, thanks
it's not one of their high-capacity traps, then.All Steamed Up, Inc.
Consulting0
- 15.8K Strictly Steam
