Backflow preventer question
Steve Nichols
Member Posts: 124
Hey all,
I'm helping a neighbor skim his steam boiler (very dirty) and I am running into an issue that has confused me a bit. The installer put a backflow preventer in between manual feed valve and boiler. The valve has a copper pipe that comes out the side (vent?) and down into a big 5 gallon bucket. Everytime homeowner fills boiler via valve, a ton of water shoots out backflow valve and some into the boiler. This makes doing a slow skim challenging. Having never worked with a BFP, I dont know what's normal, but this just doesn't appear correct.
Can they be installed "reversed" and cause this to happen? Could there be crud in the valve? I started to feed the water and covered the end of the copper "downpipe" with my thumb. When I removed it, the flow had minimized and we are now able to keep a flow going into the boiler to do the skim.
Thanks in advance,
Thanks in advance,
If you can post pictures...
they're often worth 1000 or more words, when trying to troubleshoot these things.0 -
pictures a comin
MTC, I'm heading over there shortly, I'll grab my camera.There was an error rendering this rich post.
If
it's backwards you won't get anything through it. It should have a direction indicator on it.0 -
heres the pic
Thanks Paul,
I think it's quieted down. Might have been some crud or something. Attached find a picture of the current setup. I couldn't find a direction indicator on it.There was an error rendering this rich post.
Directions:
It will say "Inlet" and "Outlet" on it.
It is required to be there. If it leaks through the outlet, it is doing what it is supposed to do.0 -
Hmmm
The arrow in the picture, might be a clue!0 -
boy do I feel stupid
You gotta be kidding. I had my face right up against that thing and I couldn't see that, and I just got new glasses. Must be time for reading glasses. Sorry for wasting your time guys, I should have seen that, but didn't. The thing was acting screwy, though and shooting all the feed water down the vent and virtually nothing into boiler. But after I plugged the end with my thumb, it stopped and went into boiler with a minimal trickle down vent.There was an error rendering this rich post.
I'd
replace it, on general priciple. It shouldn't function like that.0 -
will do
Thx Paul, I'll suggest the HO replace during summer. Hopefully today's skim makes it behave a lot better. To me it appears that the steam pros that sized it did really well matching connected radiation to boiler size. It doesn't really trip off on pressure all that much despite main venting that could be better.There was an error rendering this rich post.
crud
will do exactly that. Once it's gone you should be fine unless it damaged the seat or the gasket (in which case you'd see a drip or a dribble.) It's also possible the pivot/shaft/spring/something in the mechanism is borked, but working the valve open and shut a few times should suss that out.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
