Disassemble Burnham V1113
Chief_Gavin
Member Posts: 2
Heh Guys,
I have to replace all the nipples of a Burnham V1113. I have takend boilers apart but to date they have all been Smiths and had gaskets on them. Anyone have any advice on breaking apart the boiler in general. I don't won't to lose our **** on this and don't want to damage any of the sections. There is a leak at the number 7 section. So we are going to take it apart which shouldn't be too bad but I am worried about the nipples. Any and all advice would be appreciated. This boiler is about 12 years old.
Thanks,
Gav
Thanks,
Gav
good luck
been there, done that. Its wasn't any fun.....Make sure you have the right size rope gasket, comes with the nipple kit if I remember correctly. I didnt have any major problems removing the nipples...tapped out slowly and evenly with a piece of round stock from behind. Hopefully you dont have to replace any sections because I dont think the newly manufactured sections fit that age of boiler. We have replaced alot of the V9 with Buderus". I personally wont do a job like that unless we go time and material after trying to fit up new sections into the V9....alot of frustration on something that should be that hard.0
