brand name for baseboard steam radiator (looks like Burnham)
Dave_61
Dave_61 Member Posts: 316
We have an old radiator that looks like the Burnham Baseray with oblong slots. It has so much paint on it that I cannot read the name. Does anyone know the brand? It looks alot longer than Burnham. Thanks
  • pipeking
    pipeking Member Posts: 252
    pic?
    post a pic, u will have better luck
  • Dave_61
    Governale Gov Board
    So I was able to read the name. It is Gov Board by Governale. Back in 2008, we had replaced a leaking one with this new one.
    Now, 5 yrs later, it has a small pinhole leak coming from inside one of the slotted openings.
    When I called the company, they said they only offer a 1 yr warranty. I would think cast iron should be warranted for 10 yrs minimum!
    Will this tiny leak continue to get larger, or should I just wait to see? Currently, a drop of water will come out and dry before it even runs down the front.
    Or is there anything repairable in it? The saleman mentioned a seal.
    Thanks
    Dave
  • Dave_61
    Would it be possible
    to rebuild radiator with push nipples between parts that were leaking? Are these rebuilable like older radiators? Thanks
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,424
    if it is the nipples
    You can get them from a Burnham or Governale supply house. I would question why they are failing before I made a repair. I have not had them leak and some are over 15 years in service.
    cell # 413-841-6726
  • Dave_61
    edited February 2013
    When I called Governale,
    They were not helpful. She basically said it shouldn't have failed but is out of warranty. Guy at supply house said he didn't expect it, but "sometimes they leak."
    Don't know what else to do except either get new radiator or repair old. Here is photo.
    That is not leaking at a push nipple
    that is a section leaking.
    cell # 413-841-6726
  • Dave_61
    So, do I
    Need to just replace whole radiator? I guess there is no recourse as it is out of warranty.
    the quick answer is yes
    you need to change the unit. You also need to find out why it is going so quickly.
    cell # 413-841-6726
  • Dave_61
    We live in a large apt building
    with 200 apts. not sure what would cause it to fail. Just got new boiler a year ago.
