Payne Furnace M#PG8MAA060155ABJA blower motor problem
CC10
CC10 Member Posts: 2
Anyone ever have any problems with blower motor assemble breaking? I had a service call where customer was complaining of loud noise when the blower comes on. Checked and found one of the leg that is screwed on to the blower housing was broken. The leg is welded onto the motor and is very flimsy. Checked all suppliers to find a 4 leg belly band but there is no such thing. There is only 3 leg belly band. Had to buy a new motor and installed it in. Two days later same thing happens, one of the leg is broken. The legs are very flimsy and weak. Anyone ever experienced this problem? Suggestions? Thanks in advance.
  • Techman
    Techman Member Posts: 2,143
    Motor bracket
    I think there has to be some sort of an out of balance blower wheel
  • jeremiah
    jeremiah Member Posts: 8
    Belly band
    Ya the blower wheel is probably out of balance. I would check that then you could always buy a three post belly band and drill new screw holes in fan housing
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    balance
    Has to be a balance problem.
