Hydronic Radiant Heat - Retrofit Help Please
Glad To Hear It
I take it your plumber isn't happy but glad you are..The lesson here is that a little homework and taking the time to fully understand the existing system goes a long way.There was an error rendering this rich post.
Everything
Still working out?There was an error rendering this rich post.
Waiting
For tile guy. Will keep you posted.0 -
Re: homeowner help
Chris, I read your posts to this homeowner and just wanted to say congrats on being very helpful and considerate to this person. Sometimes I find people to be not as considerate and helpful as you were and I appreciate that. Way to go. Tim0 -
Thanks Tim
Appreciate the kind comment.There was an error rendering this rich post.
Update?
How are we making out?There was an error rendering this rich post.
Radiant Heating
First make sure you get a vapor barrier, a good tile guy will know how to best do this, moisture causes cupping with wood, not heat. If they forgot to install a vapor barrier, they probably didn't insulate under the slab, you said there was a crawl space under, if you have a suspended slap you could get some much needed insulation there. I would add pex, no matter what the calcs come out at, because more is always better, by allowing your system to run at lower, more efficient temps.
Thanks, Bob GagnonTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Double Post
Done!
I installed a new slab sensor in the mud job that the tile guy did over the existing base. The tile installation came out pretty good. I have slowly ramped up the floor temperature and the surface temperature of the tile is only a degree or two cooler than the reading from the slab sensor. Room temperature has been comfortably maintained. So it is working just fine. Room is far more comfortable with the tile versus the prior oak floor. Overall, I think I made the right decision to keep what we had and not re-create the wheel.
Thanks to everyone for their input and especially to Chris for his sound guidance. You saved me quite a bit of money. Thanks!!0 -
Great To Hear
A little donation of a few bucks of that savings to the Wounded Warriors Fund to help a fellow brother in arms would be a nice gesture. Pay if forward!There was an error rendering this rich post.
Will Do
Thanks again0 -
Great Gesture
Thank you and enjoy the warm, comfy floors.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 870 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
