Color of soot in boiler chamber
SchenleySeven
Member Posts: 27
in Oil Heating
My Columbia
boiler with Beckett burner has had an annual “tuneup” for 25 years, and the
chamber had always had a thin covering of black soot except at the rear where
the flame licked up against it. This season after the tuneup, I noticed a tan
to light brown covering that now includes an almost whitish stuff in the rear
of the chamber.
On a gas car, a light brown colored spark plug would be
good, but whitish would mean a lean mix.
Has the Beckett been adjusted incorrectly? Or, is it running
correctly now but “rich” for the past 24 years?
Thanks.
of the chamber.
Thanks.
One pipe steam, Weil-McLain 380 , pipes mostly insulated, 32 radiators!
Bock 32E water heater, Bock M-SR burner with .75 80A nozzle.
You worry too much.. lol
Could be the sign of a venting problem or condensation problem, but most likely just the white powder from the stuff they add to our heating oil.... As long as it isnt sooting up, you should be fine, did they do an efficiency test?0 -
soot
is a bad word. They probably had the wrong nozzle in it originally, and you were getting incomplete combustion. That is why the only clean spot was the center of the target wall, which it shouldn't be reaching anyway. What are you combustion readings? Boiler model #, pump pressure, nozzle specs, etc?0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
