Hearthstone Hydronics
ddr
ddr Member Posts: 14
Has anyone come across a Hearthstone boiler? We have a customer that had one installed and he has had combustion problems, I'm guessing, from day of install. It is a direct vented unit. I can not track down any info from the manufacture. M#H-4, S#AN523372.
  • kcopp
    kcopp Member Posts: 4,610
    Hearthstone....
    is the same boiler as a Biasi b10 series. Its a decent unit.  What are the units specifics... burner, boiler size.? Direct vents are a real pain especialy w/ a Becket AF2 burner...
    Hearthstone made a go of it for awhile w/ boilers then dropped the line and concentrated on wood stoves.
