Baseboard Calculation Question
knotgrumpy
knotgrumpy Member Posts: 209
What BTUH rating should I use for 1 1/4" iron pipe fin tube baseboard?
Thanks,
Mark
  • heatpro02920
    heatpro02920 Member Posts: 991
    depends on a lot of things
    Do you know the manufacturer?
    If all else fails you can use some math, if you know the ambiant temp, temp going in, temp going out, should be able to figure it out... then divide that by how many feet in the test board for per foot number....
    Stuff I have used was 800btu at 200* but may be different that what you have..
  • Pughie1
    Pughie1 Member Posts: 136
    Slant Fin
    Try Slant Fins web site, look under commercial baseboard for a model
    that is close to your model's demensions, they show several. That would probably
    be close enough.
