Baseboard Calculation Question
knotgrumpy
Member Posts: 209
What BTUH rating should I use for 1 1/4" iron pipe fin tube baseboard?
Thanks,
Mark
Thanks,
Mark
depends on a lot of things
Do you know the manufacturer?
If all else fails you can use some math, if you know the ambiant temp, temp going in, temp going out, should be able to figure it out... then divide that by how many feet in the test board for per foot number....
Stuff I have used was 800btu at 200* but may be different that what you have..0 -
Slant Fin
Try Slant Fins web site, look under commercial baseboard for a model
that is close to your model's demensions, they show several. That would probably
be close enough.
