standby heatloss on a ci boiler
pipeking
Member Posts: 252
is not good. the standby heatloss on an indirect water heater is awsome,in some cases amazing. now why can't i get comparable rates from a conventional boiler? has anyone tried to improve on this downfall?
Standby
So long as the boiler is losing the stand off in a conditioned space not worth the hassle. Unconditioned another matter. But then again if it is a big deal get a mod/con, after all CI boilers are sub 90% anyway. I would assume manufactures are directing their efforts to the real,efficiencies. Oh wait mod ones are no more than 90% now.0 -
well....
now i know u won't have to go add insulation to this awsome conventional oil ci boiler that is 90% efficient!!!http://www.buderus.us/products/oilheating/oilconventional/logano-g125be.html
but what the hell, conventional boilers should not be warm to the touch!0 -
the best answer is
to reduce or eliminate standby time, which will then reduce or eliminate standby losses.
There are a number of strategies which can reduce standby time. Eliminating it requires either modulation or significant staging.0 -
REDUCING
standby time is making the load load more efficient, right. and if thats right, then the only way i can see if it extending the standby heat loss is if if the boiler was in the conditioned space. is that what your sayin?0
- 167 Indoor-Air Quality
