base board heat thermostat
zepfan
Member Posts: 449
does anyone make a line voltage,electric heat thermostat that is digital? most of the ones that i have seen just have a temperature scale or a wamer-cooler scale.thanks to all.
Johnson Controls
Mod A-419. This is somewhat of a stand alone t-stat w/ a remote sensor. Can be used for 24vac or 110vac. Make sure you get the correct one. Appearance is not exactly like a regular t-stat, but offers a wider differential. Note; it's not set back, just a standard type stat. I'm sure someone carries the digital display but the trick is finding one.....
Peace
Mike T.0 -
- 15.8K Strictly Steam
