Heat/cooling load calcs for finished semi-conditioned basement
Reyesuela
Member Posts: 6
Here's the deal: Dad's got camping/fishing stuff. A LOT of stuff. And my parents are adding on to my house, and my dad needs a place for his stuff that is reasonable climate controlled. So we're looking at a basement.
In this area, we should do fine with a dehumidifier and no A/C in the basement storage, but I need to find out what kind of heat load I should be calculating for. Obviously, the ground temp will be considerably higher than the air temp in the winter, but I don't know how to account for that with heat load calcs.
Help, please? How can I find out what ground temperature to use?
Where are you located?
In what city and state do you live?There was an error rendering this rich post.
location
Near Washington, DC.
Thanks!0
