EDR of Steam Mains
Ban
Member Posts: 79
We are trying to figure the total EDR of our building and are having difficulty with figuring out the main on this particular system. We calculated the EDR of our radiators to be 1146 sq ft. If the pick up is .333% for the mains, that would leave us with 378 sq ft.
The system is a one-pipe with a 4" main and we have evidence that it used to be on a district steam system. The main is run in a near full-circle around the building to the boiler, as seen in the photographs below. Half of the main is a counter-flow and the other half a parallel-flow. We are concerned that the main might be so large that we need to account for more then .333% so we are trying to determine the proper EDR for mains. We cannot find any solid information on how to determine this. The entire loop of the main is currently insulated with 1" fiberglass and is approx. 125' long.
Advice is appreciated.
Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)
edr is surface area
so figure the surface area of your pipe.Cost is what you spend , value is what you get.
cell # 413-841-6726
Ok
Are you referring to the inner surface area of the pipe or the outer? How does the insulation factor into calculating a proper EDR? Is there a good publication that has all of this information complied?
Thanks.Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)0 -
Pick up
The pick up is also the run outs and riser. I would think it also is the energy needed to heat up the boiler to make the steam and all the near boiler piping.0 -
Lost art of Steam
has all the answers you seek.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
