Is it easy to change a bleeder valve
rb320
Member Posts: 1
My bleeder valve connected to the baseboard heating is leaking. How easy is it to change the valve. Attached you will see a picture of the valve.
auto vent
Thats an auto vent, you dont want that there, relplace it with a key vent, coin vent or 1/8 inch jomar valve ( ball valve). you will need to drain the system press. and lower the loop temp. when the job is done you will need to vent and purge system. recommend you get a pro not a job for a homeownerThere was an error rendering this rich post.
Jomar valve
Found their website but not sure what model you're referring to. Got a pointer?
TIA...0 -
valve
Sorry should have been clearer, its 1/8 inch ball valve, male x female or use a 1/4 inch and reduceThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
