5" main
Gary_17
Gary_17 Member Posts: 38
Splitting 1 boiler into 2. Boilers only require 3" header. Will that work with the 5" mains or do we need to build 2 5" headers? Trying to avoid welding.
    Steamhead Member Posts: 18,187
    The boiler headers can be 3-inch
    but the outputs from the boiler headers should go into a larger drop header. Dan has a diagram of this on page 67 of Lost Art.
    Consulting
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Welded headers effect on boilers
    Best to use threaded steel, as there is a little play in the joints for expansion and contraction, which could put undue stress on the sections, and their gaskets.
    There is the same problem with copper headers.
    Using a drop header makes it easier to fit, and avoid expansion problems.--NBC
