Solar thermal connection to Burnham V73
Want to optimize solar thermal hot water with Burham oil-fired boiler; thoughts on where to connect; from thermal storage to boiler; from thermal collector to boiler to thermal storage... I would like to use the boiler as backup for hydronic heating; using the solar hot water first domestic hot water and second for heating. I'm thinking that if I could keep the water temperature in the hydronic system constant at say 100-120 F ambient would stay constant, boiler would be used less. Any and all thoughts welcome please...
Use a buffer tank
pipe the heat sources in and out through the buffer tank and apply proper controls.Cost is what you spend , value is what you get.
cell # 413-841-6726
a number of ways to do that
do you make DHW with the boiler now? Unless you have a fairly large array, and some low temperature heat emitters, you may not get much solar contribution, to the heating system.
You could run a solar simulation and determine how much collector area would provide how much energy in your location.
But DHW pre-heat is a good year 'round use for solar.
Here is a book full of piping options for solar combi systems.
http://www.caleffi.us/en_US/caleffi/Details/Magazines/pdf/idronics_6_us.pdfBob "hot rod" Rohr
Living the hydronic dream0
- 15.8K Strictly Steam
