Dole 80 vents?
Does anyone has experience with Dole 80 vents. We ordered Gorton Ds from our supplier and he sent these saying they were the same. I'm 99% sure that's BS, but wanted to check here before sending them back. They are not listed in the Balancing Steam spec sheet so I'm unsure how fast they are...
Thanks!
  • Rod
    Rod Posts: 2,067
    Dole #80 "D"
    Hi- Attached is the Dole Vent chart. Score down and it gives a description of the # 80 & 85 vent including the vent aperture sizes. For the "D" model it is .185 which is the same size the Jacabus Maid -O-Mist "D" model   http://www.maid-o-mist.com/jacobus.html   so it would seem these are a close match to both the Maid-O-Mist and Gorton "D" models.
    - Rod
  • Travis_F
    Travis_F Member Posts: 14
    Thanks..
    They do vent fast, but they don't close when steam hits them... they vent all the steam. Don't know if that's just a quality difference between Gorton and these? Everyone of the forum seems to like the Gorton vents.....
  • Rod
    Rod Posts: 2,067
    Dole Vents
    Hi- The Doles are a bi-metal vent the same as Gorton and Jacobus (Maid -o-Mist) so I don't know why they wouldn't close. I haven't used them myself as they seem to be regional (more in the midwest) and are rarely seen here in New England.
    - Rod
