Dunham 220 Air Eliminator Air Check Valve
SEM001
Member Posts: 1
I have a Dunham 220 Air Eliminator that uses the Dunham 222 Air Check Valve. The disc for the valve is missing (I have no idea what happened to it). Where can I get a disc for the check valve or what air check valve should I get to replace the Dunham 222?
Dunham Air Eliminator 220
What did you end up doing with the Air Eliminator? I have a 220 as well and used a small copper disk to replace my disk made out of roof flashing to fabricate mine.Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)0
