Maid -O-Mist vents
Dealcp88
I needed to get some vents and the only ones available locally were the Maid -O-Mist vents. I am surprisingly pleased with them. The price was under $9.00 at Home Depot. For the price you can't beat them. We will have to see how they hold up.
I like them too.
I like the way you can swap the orifice spuds without having to remove the vent, and if they get clogged you can just soak the orifice spud in vinegar, which could damage the rest of the vent if you had to soak the whole thing.Just another DIYer | King of Prussia, PA
versitle
You can buy the orifices for about a deuce each which is really handy.
3PSI gauge0
- 120 Geothermal
