Nest Thermostat Not Getting Power
FCYP2
Member Posts: 1
I am trying to install a Nest thermostat in place of my Lux TX1500E Smart Temp Programmable Thermostat. The Nest is telling me the Rh isn't supplying enough power. I have Weil-Mclain WGO3 Oil Boiler with a Carlin 60200 Primary Control. The Carlin says it is 24 VAC and the 2 thermostat wires come directly from the TT on it. Is it even possible to install the Nest on this system? Do I need to have another transformer added? Any help would be greatly appreciated. Thanks.
seperate power source
I would say yes0 -
is your thermostat wired directly
to the carlin primary control? or to the aquastat? If aquastat, which one is on your boiler.There was an error rendering this rich post.
- 117 Geothermal
