in-line duct fan
Biz
Biz Member Posts: 1
I want to wire a Suncourt 6" in-line duct fan into my duct to help  airflow to an upstairs bedroom. I want to hardwire it to the blower motor so it only comes on when the blower is on. I have a york furnace with White-Rodgers control module 50A50-241. From reading another post I have an open eac on the neutral an open eac on the positive.Will this work for me?
Thanks for your help
Biz
  • unclejohn
    unclejohn Member Posts: 1,833
    Never seen
    Those in line fans accomplish much. But there should be a amp rating on the board info and if the fan is lower then the rating it should be no problem.; If its higher your board is toast..
