hot water boiler
Bob C._2
Member Posts: 31
hi-effeciency hot water boiler munchkin-runs fine until water temp reaches 160 degrees or higher then starts bouncing sounds like boiler full of air-any thoughts?
water flow
sounds like the boiler needs more water flow. what is the water pressure?0
- 120 Geothermal
