Wireless switch
plumberdan38
Member Posts: 9
Do they make a wireless switch for the zone valve. I have a thermostat wired to a zone valve which it opens but the end switch of the zone valve is not wired to the boiler. Do they make a wireless switch that will be wired to the zone valve and then wirelessly turn on the boiler?
Probably
Cheaper in the long run to use a zone valve control and pull a wire.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
