Honeywell concentric radiator valve
Gary P
Gary P Member Posts: 15
I think I have what is called a concentric radiator valve, It has one connection to the radiator and 2-3/4" connection to the hot water heating system. I read about it in one of Dan's books, but can't remember which.
I am looking for a replacement valve or parts. Some one has removed the union 90 and I am stuck.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,709
    Unique Valve
    Here's a link to the patent (thanks to Gerry Gill!)
    http://www.heatinghelp.com/article/153/Older-Hot-Water-Systems/1213/Mark-C-Honeywells-Patent-for-the-Unique-valve
    I don't know of any parts for this.
    Retired and loving it.
  • Gary P
    Honeywell Radiator valve
    Dan,
    Thank you for the help, my customers previous plumber took the union half away to match it up. Never heard back from the guy.
    I offer the customer to convert it to 2 pipe.
    Customer loves his radiators, recently had the whole house radiators refinished and powder coated.
    First house I have come across theses valves.
    I have attached a photo of a placard I came across at a recent steam boiler change out. Though you might like it. Job in Watertown CT
    Unfortunately my demolition guy scraped it with the boiler.
    Thanks for all your help.
    Have a nice holiday.
  • DanHolohan
    Nice!
    Great advice. Thanks for sharing!
  • They are replacements for those....
    one of the European makes   Danfoss,  Macon.....makes a single entry hot water valve.
  • clammy
    clammy Member Posts: 3,251
    Oventroupe
    Oventroupe makes asingle entry valve but as far as i know it's orination is differnert but take a look thru there catalog they may have it except i have not seen one ,with a little imagation and using a dip tube and a cross tee you can make one the operates simalar ,i have a large steam rad that i converted to a hot water rad using a onnly one side with supply and return and a dip tube inserted 3/4 of the way into the rad works very well .Hope this helps peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
