Honeywell concentric radiator valve
Gary P
Member Posts: 13
I think I have what is called a concentric radiator valve, It has one connection to the radiator and 2-3/4" connection to the hot water heating system. I read about it in one of Dan's books, but can't remember which.
I am looking for a replacement valve or parts. Some one has removed the union 90 and I am stuck.
Unique Valve
Here's a link to the patent (thanks to Gerry Gill!)
http://www.heatinghelp.com/article/153/Older-Hot-Water-Systems/1213/Mark-C-Honeywells-Patent-for-the-Unique-valve
I don't know of any parts for this.Retired and loving it.0 -
Honeywell Radiator valve
Dan,
Thank you for the help, my customers previous plumber took the union half away to match it up. Never heard back from the guy.
I offer the customer to convert it to 2 pipe.
Customer loves his radiators, recently had the whole house radiators refinished and powder coated.
First house I have come across theses valves.
I have attached a photo of a placard I came across at a recent steam boiler change out. Though you might like it. Job in Watertown CT
Unfortunately my demolition guy scraped it with the boiler.
Thanks for all your help.
Have a nice holiday.0 -
Nice!
Great advice. Thanks for sharing!Retired and loving it.0 -
They are replacements for those....
one of the European makes Danfoss, Macon.....makes a single entry hot water valve.There was an error rendering this rich post.
Oventroupe
Oventroupe makes asingle entry valve but as far as i know it's orination is differnert but take a look thru there catalog they may have it except i have not seen one ,with a little imagation and using a dip tube and a cross tee you can make one the operates simalar ,i have a large steam rad that i converted to a hot water rad using a onnly one side with supply and return and a dip tube inserted 3/4 of the way into the rad works very well .Hope this helps peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
