Repacking Steam Rad Valves
Happy soon to be Thanksgiving all!
Question:
On my one pipe system 3 out of the 8 rad valves are leaking steam at the valve.  They need to be repacked.  Any ideas on which packing I should use before I start wandering around the plumbing supply store?
Both for the stem and the seat connection just under the stem.
Thanks for info...
JLG
"Hey, it looks good on you though..."
  • Valve packing
    Graphite impregnated string is used for replacing. What is your pressure? --NBC
  • Steam_Starter
    Steam_Starter Member Posts: 109
    Pressure?
    NBC:
    just under 2 psi out
    0.5 psi in
    I used the string and lo and behold, no more leaking!
    Sorry it took so long for me to respond but I have been "recovering" from Thanksgiving..
    JLG
  • Rob_40
    Rob_40 Member Posts: 59
    Tighten the Packing Nuts.
    I just repacked my radiator shutoff valves a few weeks ago, and found they loosened up.  I think the string settles in after a few heating cycles requiring the re-tightening of the nuts to seal the valve stem.
  • Ban
    Ban Member Posts: 79
    Packless Valves
    How does the Dunham packless valve work (they have wood handles). I have yet to take one apart.
    Richard Ban
    Detroit, Michigan (Dunham 2-pipe vacuum)
