What Is This Tapping For?
Bob Gagnon plumbing and heating
Member Posts: 1,373
Customer is getting co reading of 200 ppm around this tapping at the top of an old american standard hot water boiler, he said it had a meter in it before they swapped from oil to gas. MassSave thought the CO was coming out of the hole, I think the top cleanouts on this boiler may need to be sealed with furnace cement, any thoughts?
Thanks, Bob Gagnon
Thanks, Bob Gagnon
I think you're
on to something. Is that a burn mark on the side of the jacket? I would at least pull the top off and look for signs of leakage. Hard to tell from pic what the tapping is for. Is it suppose to be for air vent/steel exp tank?There was an error rendering this rich post.
Aquastat well
If I remember correctly, the high limit was usually mounted on top, and reverse aquastat ( or maybe operating) was mounted in coil on rear. Probably leaking between sections and and exiting thru opening. That boiler will probably last another 50 years,but a new boiler will be much more efficient.0 -
Looks like
it could have been for the water temperature control, Bob.Retired and loving it.0 -
New Boiler
Thanks Dan, the customer is going with a new boiler.
Bob GagnonTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Wise customer
making a grand choice!Retired and loving it.0 -
As Dan said
Looks like the tankless coil was taken out of service, and the control removed. That burn mark is nothing to worry about. That is an Amercan Standard Arcoliner wet base cast iron boiler. It is not efficient, and good idea to replace it, but it will outlive whatever you install in it's place.0 -
and the CO
probably chimney/draft problem, and the 2 doors in the front occasionally needed cement to tightly seal them.0
