Repacking Steam Rad Valves
Steam_Starter
Member Posts: 109
Happy soon to be Thanksgiving all!
Question:
On my one pipe system 3 out of the 8 rad valves are leaking steam at the valve. They need to be repacked. Any ideas on which packing I should use before I start wandering around the plumbing supply store?
Both for the stem and the seat connection just under the stem.
Thanks for info...
JLG
Question:
Thanks for info...
JLG
"Hey, it looks good on you though..."
Valve packing
Graphite impregnated string is used for replacing. What is your pressure? --NBC0 -
Pressure?
NBC:
just under 2 psi out
0.5 psi in
I used the string and lo and behold, no more leaking!
Sorry it took so long for me to respond but I have been "recovering" from Thanksgiving..
JLG"Hey, it looks good on you though..."0 -
Tighten the Packing Nuts.
I just repacked my radiator shutoff valves a few weeks ago, and found they loosened up. I think the string settles in after a few heating cycles requiring the re-tightening of the nuts to seal the valve stem.0 -
Packless Valves
How does the Dunham packless valve work (they have wood handles). I have yet to take one apart.Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
