Equalizer up-size OK?
Timco
Timco Member Posts: 3,040
So this Peerless 300k wants 1)3" or 2)2" supplies and a 3" header. No problem. My wet return is 1.5" and my return tapping is 2". I was planning on a 2" equalizer and return with the 1.5" tie in at loop connection. The chart says 1.5" equalizer for this beast. Is upsizing to a 2" equalizer a bad move in any way? I'm thinking 3" all the way.
Tim
Just a guy running some pipes.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,523
    No prob
    The bigger the equalizer the better. All of my equalizers are 2". Bigger equalizer will help stabilize water level and help keep water out of mains and radiators. GO for it!
  • 2" Equalizer
    I always use 2", I think Dan told us at a class that bigger was better.
    Thanks, Bob Gagnon
