crown,new yorker,slant finn
jonny88
Member Posts: 1,139
in Oil Heating
Hi my supply house has these three oil fired boilers in stock.home owners budget cant go for a burnham.i hear crown makes a good boiler.im not very familiar with oil boilers but of the three which would be the best.heat loss was done and correct size boilers are available.thanks
Crown
Is owned by Burnham Holdings. The AWR is the same cast as the Series 2, 3, ESC and ES2. The FWZ is the Burnham MPO Block and the TWZ I believe is the V8 block as the Burnham foundry is now pouring their iron for them. So if you like Bunrham it is the same product in a different jacket with a little control difference in some boilers.
Stock both Crown and Burnham..There was an error rendering this rich post.
thanks
when you say stock both crown and burnham does that mean you have a supply house and if so where.i will travel as i am having problems getting controls etc on long island.thanks0 -
Hicksville
Yes, we have a branch in Hicksville and I just happen to be there today..I have 3 and 4 section Crown with and less coil in stock as well as gas boilers.
Universal Supply
120 New South Road
516-348-7750There was an error rendering this rich post.
crown,new yorker...etc...
like crown...have put in quite a few...customers happy....good boiler for the money...0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.6K Strictly Steam
