Air Conditioning not working?
Holmes
Member Posts: 7
Hello Friends,
I had my Air conditioning re gassed less than 12 months ago and its
now blowing warm air, is this right? How long should it last? Is there a
fuse could I check?
Thanks
Steve Holmes
fuse could I check?
Thanks
Steve Holmes
A Few Things...
If the A/C needs additional charge every year, there is a leak somewhere in the system. The out door condenser should be running when calling for A/C. If not, check breaker. Winter is here for most of us, so where do you live? Since your A/C is a closed loop, it should never need to be charged. Make sure the indoor blower is running and filter is clean.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
