turkey day
bobby b
Member Posts: 17
well the turkey is in the oven.two weeks ago i was pulled out af retirement when my friends in oceanside needed help so i loaded up the truck with a boiler,hot water tank and all the fittings i needed ,,,it was time to volunteer and go to work.my heart goes out to all of the sandy victims.keep the faith .bobby b
Nice Job
Looks like you didn't forget how to do it.
Ed0 -
Hi
Looks good -
I like your choice of oil boilers.
Question
With the cost of copper these days why didn't you run the black return pipe up higher to save on cost?
also why didn't you use pumps with check valves built in instead of the flow controls?
Job looks good.0
- 50 Industry Classes
