Steam radiator leaking at inlet (not valve but pipe)
Hello,
I recently replaced the vent on a non-functioning radiator, and now the radiator gets hot, but it is leaking a lot of water (like a cup every half hour) from the threaded pipe at the inlet after the valve.
What can I do to prevent the leak? Unfortunately, I can't even turn the radiator off because the valve seems to be missing!
Since I'll be leaving for a week for thanksgiving, I'd like to at least turn the thing off to prevent the leak, if the real fix is more time consuming.
Thanks!
  • BobC
    BobC Member Posts: 5,523
    RTV?
    Have you tried tightening that union nut? If that does not work you might try moving that radiator a bit and then cleaning both faces of the union. After that I would apply a light film of high temperature RTV to the face of the union and then tighten it back up.
    Bob
    3PSI gauge
  • BobC
    edited November 2012
    Dupe
    3PSI gauge
  • Thanks!
    Thanks! Tightening the union bolt seems to have stopped the leak. Obvious in retrospect, but I know so little about these things I am always afraid if I turn the wrong bolt I'll send steam and water all over the place.
    Thank you. Now to insulate some pipes...
