Hydronic Formula no.5 boiler cleaner
acl10
acl10 Member Posts: 349
Hydronic Formula no5 boiler cleaner.
Anyone else try this in their boiler. I put it in my steam boiler and it keeps the water clean. Is there any problem with using this in the boiler
  • dirty water
    the water from the city supply should be pretty clean, unless you know otherwise, so why use this additive, unless you have shares in the company.--nbc
  • acl10
    rust out
    Before I put it in the water would come out dirty at first now that I put it in the water in the boiler stays clean.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Makes ya wonder
    What was wrong with hydronic formulas 1 thru 4?
