Hydronic Formula no.5 boiler cleaner
acl10
Member Posts: 349
Hydronic Formula no5 boiler cleaner.
Anyone else try this in their boiler. I put it in my steam boiler and it keeps the water clean. Is there any problem with using this in the boiler
dirty water
the water from the city supply should be pretty clean, unless you know otherwise, so why use this additive, unless you have shares in the company.--nbc0 -
rust out
Before I put it in the water would come out dirty at first now that I put it in the water in the boiler stays clean.0 -
Makes ya wonder
What was wrong with hydronic formulas 1 thru 4?Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 167 Indoor-Air Quality
