is it safe to fix a boiler that was submerged
jonny88
Member Posts: 1,139
hi,so sandy has come and gone leaving a mad scramble for boilers and water heaters.utility company has said it is dangerous to try to relight boilers that were exposed to salt water.i do however see a lot of guys drying out boilers and fixing them.whats your thoughts.
Boiler
DON'T DO IT!!!
Seriously... Don't do it. There are a few threads here on the same topic. They're worth reading.0 -
whats your thoughts
I hope they have good insurance.0 -
Either replace it completely
or walk away. Period.All Steamed Up, Inc.
Consulting0 -
It can be done
Check out , The movie, Assault on a queen, with Frank Sinatra.0 -
Visit
Any Water Heater, Boiler, Furnace or AHRI web siite. The answer is pretty clear.There was an error rendering this rich post.
It can be done:
You can pull the pin out of a hand grenade and store the pin in a safe place, and walk around with an armed grenade.
It's just not a very good idea. Walk and sleep carefully. It might go off when you don't expect it.0 -
water
IF we are talking about a cast iron boiler then WHY not.
Go at it with a garden hose to wash off the salt. Then replace the gas control valve and any electronics.
Remove the burners and pilot assembly and CLEAN them.
Havn't any of you guys cleaned a sooted up boiler with a garden hose. That is one way the manufacturer reccomends.0 -
also interested in the why not answer
I keep hearing that its cast iron and stainless, washing it well, replacing gas valvue and electronics and it will work... only thing is that the insulation R value will be reduced once it dries and I can live with that0 -
Re: submerged boiler
I feel you should check with the mfr. We have repaired many boilers that have had there components wet. We replace any electrical/elcectronic components. Gas controls. Clean burners, pilots, check refractory if present. Fire off and test. But if mfr says it has to be replaced, or insurance company, replace it. What do you think they will say?
Maybe I should tell the hotel that has had its 2 million btu firetube boiler flood maybe 4 times over the last 15 yrs to replace it???? I could have sold 4 boilers? Have to make sound decisions on what we do and make sure all is safe. Tim0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
