Conversion from oil to propane
Steve Garson_2
Member Posts: 712
in Gas Heating
My sister lives in Belfast, ME and heats with oil for hot water boiler. While I realize most oil boilers are only certified for oil, what are the concerns if a Carlin EZ Gas for propane was installed? The have a stainless steel chimney liner.
Any idea what the comparable per BTU cost of propane is compared to oil?
Thanks.
Steve Garson
Boston, MA
Thanks.
Steve Garson
Boston, MA
Steve from Denver, CO
do the math
Prices from her local suppliers will be necessary http://www.eia.gov/neic/experts/heatcalc.xls0 -
Propane isn't cheap
In Mass. propane is about 20% more expensive than oil on a BTU basis, a gallon of oil will produce 140,000 BTU's while a gallon of propane is 92,000 BTU's.
I don't know what the prices are in Maine but I'll bet the differences are similar.
3PSI gauge0 -
Figure it like this:
We'll call a BTU a penny ($0.01) Take two one gallon buckets. Put 91.000 pennies in one bucket (LP Gas). Put 139,000 pennies in the other (#2 heating oil).
Compare the price of the different fuels and which bucket is the better deal.
The efficiencies are about the same. And if you put a gas conversion burner in an oil boiler, the efficiency is usually less.0 -
Depends on what burner you use
some of the older gas conversion burners weren't so good, but a Carlin EZ-Gas, Midco EC or Riello gas burner will do as well as an oil burner.All Steamed Up, Inc.
Consulting0 -
Propane
20% less than oil in Maine.Steve from Denver, CO0 -
Propane
prices
20% less per gallon or per BTU?0 -
Not to belabor the point
I scanned the cost of oil in Portland and it was about $3.40 a gallon and that buys 140,000 BTU's of heat. Propane is about 91,000 BTU's per gallon so it only contains 65% as much energy and you have to buy 1.54 gallons of propane to get the same amount of heat as would get out of a gallon of oil.
If you can get propane for $2.20 a gallon you would be getting about the same amount of heat (2.20 X 1.54 = 3.39) as you get out of a gallon of oil at $3.40. just be sure your comparing apples to apples before opening up the old wallet.
3PSI gauge0 -
Just a couple things
While the straight but comparison is a part of the story, one of the great benefits of the gas conversion is you can buy some technology. The benefits of a modulating gas will deliver greater efficiency over a season. As well, you can eliminate an old chimney. One of the best things about lp is you can buy your own gas tank and get sufficient storage to make it through the season without the mis season buys. I paid $1.44 this summer and have sufficient storage to make it thru till spring. Don't recall exactly but I think ME limits you to 2 330 gal oil storage tanks and they have to be inside. You can bury your LP tank. Also, no fuel will be as sensitive to political upheaval around the world as oil.0
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
