Wanted - Heat Timer EPC panel for parts
Mike Kusiak_2
Member Posts: 602
I am looking for and old Heat-Timer EPC steam control (green panel) <strong>with 30 minute cycle time</strong>. Need not be working. What I really need is the 30 minute cycle motor to convert an existing 60 minute cycle model to 30 minute cycle.
If anyone happens to replace one of these with a more modern control, let be know before you dispose of it.
Thanks, Mike K.
Thanks, Mike K.
HEATTIMER
Why don't you just make another cut out on the wheel?Gennady Tsakh
Absolute Mechanical Co. Inc.1 -
pulling heat-time epc
I need help picking a replacement and then I will pull the EPC
We have a WM eg-75 steam only boiler and I would like a simple timer with weather man only.
I would like to cycle the boiler on for morning and early evening use. most all residents are not here during the day. Not much more than that
Joseph0
- 15.8K Strictly Steam
