Please help stuck in disaster zone
Mark631
Mark631 Member Posts: 3
Have a erator that powers my burner. I hooked it up to the main power feed and the aqustat powers on and the burner fires up but it won't curculate the water so took the power off the burner and hooked it up to the cerculator and that worked. But then when I hook the power back up to burner its out of water it seems. I'm on long Island and it's a war zone here, forgive me I'm also typing all this out from a phone. So spelling is way off
Also the aquismart stays in standby and that was the main problem. Beckett aquismart single zone, I think it's a reallo burner.
  • Mark631
    Generator
    I'm using a 2000 watt generator to power it. It's heat only. No hot water
  • Paul48
    Paul48 Member Posts: 4,469
    If
    it's a triple aquastat it won't circulate the water until it's up to temp.
  • Mark631
    175
    It got up to 175, now it won't get above 125
  • SWEI
    SWEI Member Posts: 7,348
    Please tell me you understand the implications of this.
  • JStar
    JStar Member Posts: 2,752
    Boiler
    First...
    Was the boiler under water? If so, do not use it!
