Bang for the buck
Brrrmont
Member Posts: 1
I find myself in the bad spot of replacing a boiler and the good spot of being able to use this opportunity to convert to a propane combi direct fired. I am seeing good info here and hove found a nicely priced Navien CH-240. My heating specialist is also offering me a Trinity at a good price. Does anyone have suggestions for a good bang for the buck system? I am not looking for top of the line but I want something that works well enough without giving problems.
Thank you all.
Thank you all.
I have used....
a number of Smith gc160/ Embassy Onex combi boilers. Peerless has it rebadged as well as Slant/finn now. It is a Cosmo gas product.
It is very compact, gives 3 gpm hot water and lets you modulate the heat. Vents in PP and is concentric. the HX is Stainless.
http://www.smithboiler.com/html/gc160-condensing-boiler.asp0 -
Well, your neighbors in NH
In Brrrrmont you might want to look at the BrrRinnai E110C;)0
