Hole in exhaust pipe
questions
Member Posts: 2
<span style="font-size:12pt">I have a high efficiency Carrier furnace, installed in 2008. I just noticed that there is a ¼ inch hole drilled into the side of the PVC exhaust pipe. It looks deliberate, but non-expert-me doesn’t think we should have exhaust entering the house. Is this hole there for a reason? see atached photo</span>
test hole
Probably a test hole for combustion analysis. See if there isn't one on both the intake and exhaust. Should be sealed with a plug or RTV silicone.0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
