Steam Radiator
Maestro
Member Posts: 3
Someone has a 6 section ornate style steam radiator and needs it replaced because it's leaking. I've checked a bunch of plumbing stores, and the only thing they have is the little short new style steam radiators. If I install a 6 section one of the newer style, will it provide the same heat output? Any advice? Thanks
That would depend
on the heat output of the old one. Can you post some front and side pics and include the height?Baltimore, MD, USA
Consulting0 -
Steam Radiator
I don't have any photos of it at the moment, but I found something really similar to it.0 -
replacement
Where are you located, I have a similar 8 section for sale.Check local salvage yards, craigslist etc, should be plenty of good used radiators for sale.0 -
Steam Radiator
I'm located in brooklyn, ny. Are you nearby?0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
- 19 Recall Announcements
