Constantly replacing thermocouple
Petey Pete
Member Posts: 13
What can be the cause of having to replace a thermocouple at least twice a heating system? On a standing pilot, gas fired, steam boiler..
pilot
If the pilot flame is too big OR too much thermocouple is in the flame it will burn it out.
ONLY the tip ( 3/8 " ) is supposed to be red.0 -
Yep,
that's the most common problem. If you have a multimeter with millivolts, you can check output between the end of the thermocouple and the outside of the wire when holding pilot valve down for a couple of minutes. The output should be about 27 to 30 MV. Also, the tip should be a dull red, not bright red after being heated by the pilot. Almost all pilots need to be adjusted down at installation because the factory typically leaves them full open at the factory.There was an error rendering this rich post.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
