Tekmar269 - WWSD is stuck on !! - HELP
Dave72589
Member Posts: 1
Hello,
No matter what I try my WWSD light is stuck on. Any help or info is greatly appreciated.
Dave
Dave
Dave
You can go to Tekmar.com and find the answer to your problem. Here you can find literature/installation/service information. Please note: the #269 has been discontinued and now is the #279 Control. Detailed info on both are available. Sounds like a possible sensor fault...
Mike T.0 -
Warm weather shut down
The WWSD is determined by the occupied dial position and the outdoor sensor temperature reading. If the outdoor sensor temperature measurement if above the occupied dial, then the WWSD light turns on. It's possible that the outdoor sensor is faulty and requires replacement.0 -
old control
I had a similar issue recently with an older tekmar control, a 354 mixing control was doing the same thing, I checked all the sensors (outdoor, supply & indoor RTU) the supply sensor was reading incorrectly and the outdoor one looked crusty & funky so I replaced them both but it didn't make any difference. So I replaced the RTU (an older 2K one no longer made) with just a regular hydronic thermostat giving the control a heat demand. It worked, the next step would have been to replace the control.0
- 50 Industry Classes
