If our community has helped you, please consider making a contribution to support this website.  Thanks!
no heat...yes gas????
                    ms_hat
                    Member Posts: 1
                                  in Gas Heating
                    My heat won't turn on...neither will my gas log. Tried lighting gas log pilot... wouldn't hold flame. My Dad tried furnace pilot...couldn't figure out how it lit. So... I have no heat. I DO however have hot water, clothes dryer and stove that all work. What is going on? The heat is gas "hot water baseboard"...I'm told.
            could be something.....
 as simple as a valve that got turned off...or it could be simultaneous thermocouple failures. Sounds like you need to call in a pro to look it over.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
