boiler make up water
BFlanzbaum
Member Posts: 26
The state inspectors here in NJ are now asking for a check valve in the boiler water feed line. System already have back-flow preventors. Do you know the correct location for this check valve. Thanks
Check valve
I've always been told that it has to be right at the boiler, after any other control.0
