Weil McClain Gas Boiler Not Working
nycpa
Member Posts: 108
Hi,
Two days ago I turned my boiler on. Just today, it stopped working. It was working fine yesterday and the day before. It was nice a quiet as always. Today, in order to fix it, I turned the thermostat and emergency switch off then on and drained and refilled the water. It still doesn't work. I attached two pictures of it. I have a steam heating system. Any suggestions on what I can do? I'd appreciate it. Thanks.
Boiler
Could be a plugged pigtail, or any number of bad safeties or controls.0 -
Bad Safety
Are most of the controls and pigtail replaceable? Is it possible that the entire boiler needs to be replaced?0 -
Boiler
Anything is replaceable, including the whole boiler. It really depends on the actual problem and condition of the system.
Where are you located? We may know somebody in the area.0 -
live
I live in Nassau County NY. A reference would be appreciated.0 -
NY
I'm in NJ, but I do work in your area. Folow my link below and I can help you.0
