Oil to NG Conversion
BostonGTR
Member Posts: 18
in Gas Heating
I’m converting from oil to NG. 13 yr old house with good insulation, windows and doors with 3 hydro-air units. Given that the hydro-air units have aquastats set at 140 degrees; what is the best boiler solution? Am I correct that a modcon unit will not be
in the “sweet spot” i.e. not condensing, due to the need to generate approximately 170 degree water for the air handlers; not to mention the need to generate hot water for an indirect DHW tank? Even if the modcon is not condensing and therefore not operating at 96% efficiency; will it still be more efficient, or at least as efficient, as a new cast iron boiler? I understand that the modcon would require some annual maintenance. Is the cast iron boiler maintenance free? The 96% modcon unit offers a rebate of $1,500; the rebate drops to $1,000 for a rating of 90%+; and then to $0 below 90%. Might you be able to recommend a “medium efficient” cast iron boiler with a 90% rating?
rest of system
Are other emitters (radiators, floor tubing, etc) involved, or just the hydro-air units?0 -
Only Hydro-Air
Just the 3 hydro-air units.0 -
outdoor reset
Works on air coils too. The curve will be higher and steeper, but it will noticeably improve comfort and efficiency. Depending on the coil sizing and the climate, a mod/con could be condensing more of the time than you'd expect.
Edit: looks like the aquastat controls the fan, so making ODR work properly would require some additional controls.0 -
Feedback
Does anyone have any experience using a modcon boiler to feed a hydro-air system? It seems that it shouldn't perform any worse than a cast iron unit; correct? I just want to make the correct boiler decision (modcon vs. cast iron) before proceeding with this heart transplant.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
