System 2000 steel & parts vs castiron boilers
dkr
Member Posts: 13
I recieved 5 estimates. One which I have asked questions about in other threads and the System 2000 are the best. Problem is every installer ripped the System 2000 because it is not cast iron, the steel doesn't conduct heat as well, endurance and if something goes wrong the parts are difficult to come by. I thought the system sounded good but the majority of boilermen killed it. Any one with knowledge have advice on system 2000?
System 2000
Use the search the wall function to see all the postings on that system.--NBC0 -
some people.....
can be objective... some can't. Not just w/ boilers either. You still did not tell us what your houses heating system was like... basebaord, CI rads....0 -
cant find info
I have searched and can not find much info. I wish someone on this site that knows about them could just give me a straight answer on the System 20000 -
Search for system 2000
http://www.heatinghelp.com/forum/search
Enter system 2000 in the box and there will be many posts concerning that system.--NBC0
